Turnigy TrackStar ESC
#361
Thank you for your answers. I will move my brake endpoint
Sorry for this off topic but i don't find similar post for my ESC on onroad. Pancar 1:10 only 2WD more easy to move alone...
https://www.youtube.com/watch?v=zYOdccTxeiM
+ YouTube Video | |
#362
To the TrackStar 120A Turbo guru's... From what I've read you cannot change the motor direction. So in the case of switching from a 3 gear tranny to a 4 gear tranny what should be done? Swapping A-C motor wires or is there something I am missing?
Looking into one of these esc's, just making sure I know everything about them before I pull the trigger on one.
Thanks,
BC
Thanks,
BC
#363
R/C Tech Elite Member
Thanks,
BC
Thanks,
BC
#364
Thanks,
BC
Thanks,
BC
If you have a deal that needs reverse rotation, the sensor harness also needs rewired. Can be done but a little tricky.
#365
Which trannies? To add to thecman's comments most of the recent 4 gear transmissions flip the motor around with the spur gear on the other side of the car. Which takes care of the need for a reverse motor rotation, they still use a normal rotation motor.
#366
I don't see any rearrangement of sensor wire connections and motor connections that would result in reverse rotation, given the fixed mapping of sensor inputs to motor drive outputs inside the ESC shown by the diagram I provided. If you know of a rewiring that will work, please let us know what it is.
#368
One item besides the wiring that needs considered for reverse rotation is the mechanical timing advance of the motor. It needs to be reversed. May be easier on some motors than others, might take some slight modding on some.
The motor A and sensor A must be kept in phase/synced with each other, same for B-B and C-C. Flip a couple phases, both main wires and sensor signal wires, so A-B-C is connected to say A-C-B at the motor. C-B-A or B-A-C also works.
This is how some of the early brushless 2wd buggy mid motor conversions were setup. If the gearbox wasn't modified to flip the topshaft and motor plate, or some variation of Paul Sinclair's X Factory 4th gear idea.
#369
I was trying to get the correct sequence without needing to rotate the endbell on the motor (or maybe only a little). It appears that a 120 degree rotation would be necessary (assuming 0 degrees advance in CCW and CW rotation). That would be easy on a Novak, but could be very difficult on other brands.
#370
Sorry if been asked but anybody used both x car and trackstar 120a? trying to decide which to get for 2wd buggy 10.5T
#374
How long has the v2 120a esc been out for and what are people's thoughts?
I've only owned two Hk Esc's and have lasted less than 4 months and five cycles. X car and gen 2 respectively running 6.5t 4wd buggy
#375
I've been running it for a while. A v1 80amp on 21.5 usgt. It has been great, so far undefeated on this category. Can't tell the difference between this and my 120amp HW. But the best thing is the price. I just bought a couple of v2 and still up for testing, so far they feel very nice. A lot of software options.
